NCC Sites best practice
I need guidance on the best way to organize a campus with multiple buildings in Nebula. All buildings connected via fiber and share internet connection and firewall at core. Should I setup each building as a separate site, or should I do the full campus as a site and use tags to group devices based on building, etc...? Pros and cons of each method in Nebula?
Thanks in advance.
Phil
Thanks in advance.
Phil
Hi @Phil_G,
Welcome to Zyxel Community!
As all the networking is in the same firewall/core, I'll recommend installing the full campus in one site, it will be more convenient to maintain, you won't need to switch org/site everytime when monitoring the current status. You may also use tags to group devices and assign SSID for specific APs.
Jonas,Jonas,0 -
Thank you! One other thing about our setup is each building has a different vlan. Is it possible to apply vlans to ports via tagging?Nebula_Jonas said:Hi @Phil_G,
Jonas,0 -
Hi @Phil_G,Thank you! One other thing about our setup is each building has a different vlan. Is it possible to apply vlans to ports via tagging?
Nope, it can't be done by tagging. However, you could use a tag to specify where the switch location. For configuring VLANs to multiple switch ports, I suggest changing the switch name to a similar one, as a label. E.g. Building A, 1st floor, 2x switches named "Alpha".
Will look like this:
Go to Switch > Configure > Switch ports, and then use the search bar to filter the switch using the name "Alpha".
It will display all the switch ports, and you may choose multiple ports to configure VLANs at the same time by clicking on "Edit" button.
Hope it helps.
Jonas,Jonas,0
- 588 USG FLEX H Series
- 477 News and Release
