Resolving LAN hostnames when connected in Host to Host VPN
Hi @ols_it
You may follow this guide to join your PC into Domain Controller.
PC can only belonging to a domain in the same time. If both of PCs are belonging to different domain, then maybe it is the reason.
NETBIOS service working on UDP 137, 138 and TCP139, 445 ports. You may double confirm these ports are allowed on your PCs.
Thanks for the reply.as the Christmas holidays, I will try in January and keep you updated.0
I put the PC in the same domain and everything works.Thanks for your help0
- 603 USG FLEX H Series
- 481 News and Release
