USG 310: SERVICES AND LOGIN DOWN
After the first 2 days in production of a USG 310 (updated to the latest firmware), suddenly it is no longer reachable from webUI while the CLI does not log in, the proxy is down, all the vpn services down, only the routing work.
The CLI login freezes:
Can I just physically restart it?
My versione firmware is 4.39(AAPJ.0), i have hard powered Off/On and now all works.
How do i understand what caused the problem?
Hi @Briz
It looks the main service has stop working in unknown reason.
We recommend to upgrade firmware to 4.60 Patch 1, since it has fixed system stability issue.
If symptom happen again, you may send your configuration to me by private message for further check.
ok thanks0
Hi @Zyxel_Stanley,
i have continuous problems, i send you our configuration.0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 913 Nebula FAQ
- 421 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
