WAX610D managed on USG 110
bavaria
bavaria Posts: 30 image  Freshman Member
edited April 2021 in Security
I have already updated to ZLD 4.60 wk48, I can see a new WAX610D in the AP List but the icon is grey.
What can i do?
On this site the WAX610D should be supported:
https://support.zyxel.eu/hc/en-us/articles/360001516539
Best Answers
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,398 image  Zyxel Employee
    Hi @bavaria
    You can try to update AP firmware to latest version and check if it can manage your WAX610D successfully.
    (Configuration > Wireless > AP management > Firmware.)
    After firmware updated completely, it should able to forward AP configuration to WAX610D.
  • Zyxel_Stanley
    Hi @bavaria
    Here is the latest release note of Ekahua.
    It looks WAX610D doesn’t in support list yet, it should be the reason the AP is unable to scan by software.
    Maybe you can wait for next update from Ekahua.
  • Zyxel_Stanley
    Hi @bavaria
  • bavaria
    Zyxel_Stanley,
    that makes my day, the AP works now.
    But the AP is now in limited mode, in the log I can find only
    "AP does not support RTLS EKAHAU,"
    is this only about this or does the AP has other problems?
    Ekahau is disabled on my site.
    THX
  • Zyxel_Stanley
    Hi @bavaria
  • danyedinak
    danyedinak Posts: 51 image  Ally Member
    bavaria
    It looks like the "Limited AP" is just an indicator that some feature is not available (in this case, RTLS EKAHAU). I don't know why this is only showing on some of these APs and not others, even within the some controller/AP combination, but I finally found this knowledge base article talking about this issue, and the steps to identify the non supported feature, here :
    https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=016576&lang=EN
