USG40W Loses Internet Connectivity
After upgrading to 4.60, and reconfiguring the router from scratch, I've noticed that the Internet connection is unstable. Occasionally, there will be a delay when clicking on a web link, or opening a new browser session. Sometimes this delay is just a few seconds, but can also be indefinite, requiring the router to be rebooted. This is happening on the Ethernet connection, so it's not a wireless issue.
I have tried a resetting, and reinstalling firmware, using firmware's new default configuration, then configuring it manually according to my needs, but the problem persists.
If you have a older firmware in the other slot and reboot to that do you have any problems?
I don't have older firmware available. I removed it.There were some problems before with connectivity, but not as bad as they are now. I have replaced the device now. However, it would be good to know if the old one is fixable.0
Hi @Jason210
It’s our suggestion that you may consider to upgrade your device firmware to V4.60(AALB.1) patch 1. This version should not have certain issue per our real field experience.
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
