Need help - how to - basic settings first
If you would like to setup loadbalance on WAN interface.
You can setup both of WAN IP addressed on ge1 and ge2 first.
(Configuration > Network > Interface > Ethernet)
And then create a customize load balance for ge1 and ge2.
(Configuration > Network > Interface > Trunk)
Thanks for your reply.However, I have issues to setup the basic.For example, I can ping 8.8.8.8 from my ge2 interface (which is one of my DSL routers)But, I can't ping 8.8.8.8 from ge3 interface (which is my default LAN interface in IP .1.1)Could you please let me know if I set correctly the interface?Interface type > General ? Internal ? External ?Zone > LAN ? WAN ?Thanks in advance for your help,LoadBalance will be next step, when I will be at least able to have internet working with one line.Best regards,0
Bilouwanadoofr said:I have 2 Asus DSL routers.IP: .1.253 and .1.254
Are you not able to put these in modem mode to pass the WAN IP's? do these routers have static route option?
For a quick double NAT test for the Zywall 310 ge1 IP 192.168.1.251 gateway.1.253 and ge2 IP 192.168.1.252 gateway.1.254 need to be External and zone WAN.incoming interfacemember LAN
member LAN
next hop
type Interface
Interface ge1
Source network network address translation outgoing-interface
incoming interface
next hop
type Interface
Interface ge2
Your LAN zone needs to be out of 192.168.1.0 so 192.168.2.0/255.255.255.0
If you can do static route on the Asus DSL routers then add to each:
192.168.2.0
255.255.255.0Gateway IP the IP of ge1 IP 192.168.1.251 and ge2 192.168.1.252member LAN
Than you can make a routing rule:
incoming interface
member LAN
next hop
type gateway
gateway IP .1.253
Source network network address translation none
incoming interface
next hop
type gateway
gateway IP .1.254
EDIT: to do static route on the Asus DSL routers gateway 192.168.254.254/24 and 192.168.255.254/24
Do static route on the Asus DSL routers then add to each:
192.168.1.0
255.255.255.0Gateway IP the IP of ge1 IP 192.168.254.253 and ge2 192.168.255.253member LAN
incoming interface
member LAN
next hop
type gateway
gateway IP 192.168.254.254
incoming interface
next hop
type gateway
gateway IP 192.168.255.254
You may try to change ge2 interface type as “external”.
Then internet traffic will able auto route traffic to internet.
Hi Guys,Thanks for your replies.@PeterUK > Why different range?Currently, with my Draytek, all is on /24 192.168.1.xIs it not possible to do the same with a Zywall?@Zyxel_Stanley > tried the change you suggested, set the ge2 interface as "external" but still not able to ping 8.8.8.8 from ge3.What about ge3 ? Internal or General? And all interfaces (ge2, ge3) in the same zone? currently Lan.Security Policies are disabled until I have something working (I will activate them later).I suppose I did something wrong or not the correct way.Thanks in advance for your future replies !!! :-)0
Having ge1,ge2 and ge3 all be 192.168.1.x may or may not work its best to have ge3 with 192.168.2.x
Doing double NAT with the Asus DSL routers with both doing 192.168.1.x is also not good and the static route setup may not work if possible use for a gateway 192.168.254.254/24 and 192.168.255.254/24
This means I have to readdress all my network devices into 192.168.2.x also ?
Ok how about changing the Asus DSL routers network for gateway 192.168.254.254/24 and 192.168.255.254/24
This way ge3 on the USG can be 192.168.1.x
In the default setting, ge3 interface type is internal and IP address is 192.168.1.1/24.
If you ping 8.8.8.8 by Interface. Then system will use “Interface IP” to Internet. [ping 8.8.8.8 interface ge3 ]
Since ge3 IP address is private address, and that’s why it is reply “Destination Host Unreachable” to you.
You may explain more detail of your scenario, then we will much understand what you need.
Hi Guys,@PeterUK > your suggestion seems more realistic@Zyxel_Stanley > for more details, here is what I currently have and what I would like to to.For now, I have 2 DSL linesI have 2 ASUS DSL routers.One is (internal IP) > 192.168.1.253The second is (internal IP) > 192.168.1.254Then, I have a Draytek Router which is a loadbalancer dual wan.Because not yet optical fiber connected, 2 DSL line is more comfortable than one.So, on the Draytek, there are 2 WAN ports configured as follow:192.168.1.251 > Gateway 192.168.1.253 (first DSL router)192.168.1.252 > Gateway 192.168.1.254 (second DSL router)This Draytek is currently 192.168.1.1 and is my gateway for all my devices.I would like, if possible, replace this Draytek by the Zyxel.And still if possible, keep same IP (I would be surprised if not possible)Please let me know if you need more details I forget maybe?Thanks a ton and have a good day !!!Cheers0
- 394 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 82 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 908 Nebula FAQ
- 415 Security FAQ
- 236 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 138 Service & License FAQ
- 73 About Community
- 62 Security Highlight
