USG40W Loses Internet Connectivity
Jason210
Jason210 Posts: 5 image  Freshman Member
edited April 2021 in Security
After upgrading to 4.60, and reconfiguring the router from scratch, I've noticed that the Internet connection is unstable. Occasionally, there will be a delay when clicking on a web link, or opening a new browser session. Sometimes this delay is just a few seconds, but can also be indefinite, requiring the router to be rebooted. This is happening on the Ethernet connection, so it's not a wireless issue.
I have tried a resetting, and reinstalling firmware, using firmware's new default configuration, then configuring it manually according to my needs, but the problem persists.
    edited January 2021
    If you have a older firmware in the other slot and reboot to that do you have any problems?
  • Jason210
    I don't have older firmware available. I removed it.
    There were some problems before with connectivity, but not as bad as they are now. I have replaced the device now. However, it would be good to know if the old one is fixable.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Jason210
    It’s our suggestion that you may consider to upgrade your device firmware to V4.60(AALB.1) patch 1. This version should not have certain issue per our real field experience.
