Add Quick Static IP
Pook
Pook Posts: 153 image  Master Member
First Comment First Answer Friend Collector Nebula Gratitude
edited July 2024 in Nebula Ideas
It would be great if you could just select a Client and have the option to assign Static IP address.
1 votes
Active · Last Updated
  • [Deleted User]
    [Deleted User] Posts: 0 image  Freshman Member
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Do you mean to specify the particular client from dynamic DHCP to the static DHCP in client page?
    Similar as USG.
  • Pook
    Sorry I should have said I meant in the Nebula portal :-)
  • [Deleted User]
    So, it's the DHCP feature, correct? :)
  • Pook
    Yes, if you could browse to Security Gateway and then DHCP leases and have a reserve option that would be cool :-)
  • [Deleted User]
    Thanks for your input, it's in our roadmap we still need to evaluate therefore the schedule is TBD, so stay tuned here. :)
  • Cyberace
    Cyberace Posts: 1 image  Freshman Member
    First Anniversary
    Yes, this is a great idea. To manage the static IP in "clients" (nebula) would be a time saving solution.
    managing the ip's under the interface is not nice. you cannot even sort, so managing is hard.
    So it would be nice to have a simple solution.
    Thank :)
Nebula Tips & Tricks
