Add Quick Static IP
Pook
It would be great if you could just select a Client and have the option to assign Static IP address.
Do you mean to specify the particular client from dynamic DHCP to the static DHCP in client page?Similar as USG.
Sorry I should have said I meant in the Nebula portal :-)
Yes, if you could browse to Security Gateway and then DHCP leases and have a reserve option that would be cool :-)
Thanks for your input, it's in our roadmap we still need to evaluate therefore the schedule is TBD, so stay tuned here.
Yes, this is a great idea. To manage the static IP in "clients" (nebula) would be a time saving solution.managing the ip's under the interface is not nice. you cannot even sort, so managing is hard.So it would be nice to have a simple solution.Thank
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
