USG60 IKEv2/Ipsec client question
Lou_S
Lou_S Posts: 5 image  Freshman Member
edited April 2021 in Security
Hi-
I'm trying to get a USG60 to connect to a vpn service as an IPSEC client.  EAP auth seems to work (logs show "AUTH Success!" message) and I get as far as "IKE SA negotiation process done" in the log.  I then seem to enter a loop where we keep sending the cookie pair back and forth forever (logs show it repeating with a client message of "Send:" and the VPN server a "Recv:" message)
I recall with site to site IPSEC in the past I used to see an explicit phase 1 complete message, not sure if the "SA negotiation process done" means my issue is in phase 2.  Does anyone know if that's correct, and why I might be stuck in this loop?
Attaching a screenshot of the loop.  USG client is 172.x.x.x and VPN server is 45.x.x.x.
Thanks for any ideas!
lou
  • Lou_S
    Sorry, I said the USG60 client is at 172.x.x.x above when it should say 173.x.x.x
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Lou_S
     There are some points that need to clarify:
    (1)  Could this VPN connection be established? Or still, stuck in this loop?
    (2)  Is the destination VPN server also a Zyxel security gateway?
    (3)  What is your VPN gateway application scenario? Are you available to provide your test topology and startup-config.conf file to me via private message?
    Thanks.
  • Lou_S
    Hi Jeff-
    Thanks for the reply.  I was trying to connect a tunnel from the router to a VPN service (Nord VPN).  Nord claims to support IPSEC/IKEv2  using Client_Role with xauth/EAP.  I dont know whose tech was at used as the VPN server.
    I was stuck in this loop for a while but gave up and canceled the service.  NordVPN support wouldn't share the needed config settings and I hit a wall.  Their refusal to share even basic info made this too hard to debug.
    Thanks anyway
    Lou
  • Zyxel_Jeff
    Hi @Lou_S
    Thanks for your feedback.
    If there is any assistance needs in the future please let us know.
