USG60 IKEv2/Ipsec client question
Hi-
I'm trying to get a USG60 to connect
to a vpn service as an IPSEC client. EAP auth seems to work (logs show
"AUTH Success!" message) and I get as far as "IKE SA negotiation process
done" in the log. I then seem to enter a loop where we keep sending
the cookie pair back and forth forever (logs show it repeating with a client message of "Send:" and the VPN server a "Recv:" message)
I recall with site to site IPSEC in the past I used to see an explicit phase 1 complete message, not sure if the "SA negotiation process done" means my issue is in phase 2. Does anyone know if that's correct, and why I might be stuck in this loop?
Attaching a screenshot of the loop. USG client is 172.x.x.x and VPN server is 45.x.x.x.
Thanks for any ideas!
lou
Sorry, I said the USG60 client is at 172.x.x.x above when it should say 173.x.x.x
Hi @Lou_S
There are some points that need to clarify:
(1) Could this VPN connection be established? Or still, stuck in this loop?
(2) Is the destination VPN server also a Zyxel security gateway?
(3) What is your VPN gateway application scenario? Are you available to provide your test topology and startup-config.conf file to me via private message?
Thanks.
Hi Jeff-Thanks for the reply. I was trying to connect a tunnel from the router to a VPN service (Nord VPN). Nord claims to support IPSEC/IKEv2 using Client_Role with xauth/EAP. I dont know whose tech was at used as the VPN server.I was stuck in this loop for a while but gave up and canceled the service. NordVPN support wouldn't share the needed config settings and I hit a wall. Their refusal to share even basic info made this too hard to debug.Thanks anywayLou0
Hi @Lou_S
Thanks for your feedback.
If there is any assistance needs in the future please let us know.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
