Is there a way for me to control Multy with both my iPhone and iPad?
[Deleted User]
Hey there, does Multy work with multiple devices for controlling or is it limited to one device to control Multy?
@ThatTom,
As I know if you don't register an account. The configuration file is only save on your iPhone. So, you cannot find MULTY when using iPad via MULTY app.0
@ThatTom,
You can use MULTY app to control your device. What is the problem that you encountered?0 -
I finished setting up Multy with my iPhone, but when I open the Multy app on my iPad it can't find the Multy.0
@ThatTom, Which iOS version in your iPad?0
I have an iPad 2017 using iOS version 10.3.30
@ThatTom,Do you have registered an account on myZyxelCloud?
Link: https://mycloud-sso-beta.zyxel.com/users/sign_inYou shoud able to find your MULTY on your iPhone and iPad when using the same account to login MULTY app.0 -
No, but I don't want to link something beta with my home router. I take it that this only supports one Multy management device without registration?0
@ThatTom
I think you are correct. I can't use MULTY app to manage my MULTY devices with multiple mobile devices either if I don't register a myZyxelCloud account and login the app.
@ThatTom,
- 588 USG FLEX H Series
- 476 News and Release
