Multy X
Sebi
Multy X AC300 tri-band router have a Firewall ? And howe many wifi SSID supported?
Yes, Multy X has the firewall function. Enabled by default.For Main SSID:1. One SSID for 2.4 Ghz and 5 Ghz.2. Two SSID for 2.4 Ghz and 5 Ghz. When you separated SSID, it will add .speed on 5 Ghz SSID.For Guest SSID:One SSID for 2.4 Ghz and 5 Ghz.2
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
