[092503]Diagnose not clear
Theo1975
Theo1975 Posts: 45 image  Zyxel Employee
Third Anniversary
edited September 2017 in Archive 2017-2020
everytime I use the diagnose, I got different results, most of the time the connection between internet and Multy-X 1 and 2 are 0. Just the connection between the Multy-X devices show a result.
So far as I understood, the diagnose is for checking the connection from Multy-X device not from client to the internet?!?
So I should get data from internet, expect the line is down.
  • Zyxel_Support
    Zyxel_Support Posts: 436 image  Zyxel Employee
    @Thorsten,
    What's the LED light of 1st and 2nd Multy X? (White Solid?)
    Can you share the firmware version of your Multy X and screenshot of Diagnose?
  • Theo1975
    Third Anniversary
    LED is solid white all the time.
    Attached you can see my results.
    Firmware is V1.00(ABKJ.1)B6
    As I mentioned before, sometimes result is ok. But the most time I got in at least one measurement no data like Internet -> Wohnzimmer (first device) or Internet -> Kinderzimmer (second device)
  • Theo1975
    Third Anniversary
    one more screenshot
  • Zyxel_Support
    Thanks for your reported, we can see the same problem in our environment.
    RD is checking the configuration of OoklaServer to find out the root cause.
  • Theo1975
    Third Anniversary
    thank you for the info.
