[100201]Is there any VLAN Tag on the ethernet Ports on the Multy X?
pancho35m
Hi Team,
in germany some providers offers multimedia receiver by ethernet. For example Deutsche Telekom uses VLAN 7 Tag for Multimedia. In this case we put the receiver on the multi on the ethernet ports and it does not work.
So question is there any VLAN Tag on the ethernet Ports?
In Nebula on the switches all vlans are tagged by system default.
BR
Pancho
BR
Pancho
We will add this feature request to wish list.1
for germany it is really important. It could be a showstopper in germany if we do not have this feature. Some consumer will put their multimedia receiver of the ISP on the Multy X.
So not only using for WiFi Access.
For comparison, Netgear's Orbi supports this.2
I totally agree to @pancho35m, we need this function for german market
Please help to clarify this request.According to product design,Multy X should be connected behind the getaway/CPE,so the getaway/CPE already have VLAN tag/untag feature,then Multy X should receive packets without VLAN id.At user's home, the topology may as below:Internet---getaway/CPE---Multy X(node1) ))) ((( Multy X(node2)Could you help to provide the detail scenario in Germany? Thanks.0
ISP (German Telekom) < - - > Fritz Box AVM < - - > Multimedia Receiver < - -> TV
On the Fritz Box AVM he has also an AP on the Ethernet Port
This environment works
With Multy X he setup the environment like this
ISP (German Telekom) < - - > Fritz Box AVM < - - > Multy X < - - > Multimedia Receiver < - - > TV
And in this case it is not working
He did not get any channel on the TV
multimedia System over multy x is still working. No other action at the moment from my side to test.0
Thanks for the confirmation.0
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
