NBG6515 Samba server
desmbr
If I mount USB disk connected to NBG6515 router on Windows PC as a remote disk it says it has FAT32 file system. Which is not very convenient because I am unable to upload large files due to FAT32 limitations.
Is it possible to change this behavior?
Thanks.
#Router_October
Thanks.
#Router_October
@desmbr
Currently NBG6515 USB file system could support FAT16/ FAT32/ NTFS/ EXT3. NTFS should could provide you more large file to store. Thank you.0 -
What's the capacity of your USB disk?
You can try to use following steps:
1. Store the data of USB disk to other place, such as NAS, PC
2. Format the USB disk as NTFS via your Windows PC
3. Store the data to USB disk
4. Connect the USB disk to NBG65150 -
My disk is already formatted to NTFS
I don't understand why I see it in Windows as FAT. 0 -
The disk is alreadyy formatted as NTFS.
- 439 Beta Program
- 2.8K Nebula
- 203 Nebula Ideas
- 6.3K Security
- 519 USG FLEX H Series
- 329 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.4K FAQ
- 98 Security Highlight
