Good morning, I did the update of the firmware of my moden since it worked very slow. I update corr
Jose1967
Jose1967 Posts: 1 image  Freshman Member
edited October 2017 in Smart Home Product
Good morning, I did the update of the firmware of my moden since it worked very slow. I update correctly, but the problem is that now I do not recognize user and password. What can I do ?. THE MODEM IS AMG1302-T10B Thank you
#CPE_September
  • Rory
    Rory Posts: 120 image  Ally Member
    @Jose1967,
    Which Firmware version in your AMG1302-T10B at present?
    It's better if you also provide old Firmware version information.
  • Johan
    Johan Posts: 27 image  Freshman Member
    If not yet solved, perform a reset on the modem then login details are admin and password 1234.
