Mounting USG210
                    Jarno_Smits
                    Posts: 23  Freshman Member
                    good morning,
bought a USG210, official this type isn't for wall mounting.
but are there some people here, that mount a USG210 to a wall already?
i want to mount it vertical to the wall,(with custom made clips ) around the USG210 there is enough airflow.
I have a USG60 and noticed this type doesn't get hot, when wall mounted, If this is also with the USG210 then i think wall mounting isn't a problem.
kind regards,
Jarno Smits
kind regards,
Jarno Smits
            Hello Jarno Smits,
 For the USG210, we suggest it should place on the table or rack(the original design), however, I think USG210 can be mounted on the wall if you keep enough airflow for ventilation hole of device,
 Charlie0
            Hi Charlie,
 Thank you for the answer, i,m gonna try the wall mounting and monitoring the temperture, there is enough airflow at the ventilation hole.0
            Hi Charlie,
 Some feedback.
 Zywall is working for a month now, wall mounted, it works without a problem, temperature is ok.0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
