zyxel p8702n and usb external harddrive
Nimili
Nimili Posts: 2 image  Freshman Member
edited October 2017 in Smart Home Product
Hi
Is there any limit to what kind of hard drive you can connect via usb to this modem? I cant find the external hard drive in the network and I have done the steps corrent in the router.
#CPE_October
  • MMrr
    MMrr Posts: 31 image  Freshman Member
    @Nimili,
    You can first check if web GUI display your USB information,
    then use FAT/FAT32/NTFS format to check again.
    What's the capacity of volume? As I know, some chipset of USB only support 2T as max size...
  • Nimili
    Thanks, I can see the usb in the router and its max 2 Tb. I can try and format it.
