Could anyone help me what is happenoing with my router please?
FrantaBrabec2017
FrantaBrabec2017 Posts: 1 image  Freshman Member
Could you check and confirm logs from my Zyxel VMG1312B30B are ok please?
2017 -10 -17 T17:17:51daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T17:17:52daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= MAC= SRC=103.217.111.222 DST=10.242.153.246 126
2017 -10 -17 T17:17:54daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T17:18:00daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T17:27:58daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= MAC= 86
2017 -10 -17 T17:37:53daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T17:47:53daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T17:55:41daemonnoticesyslog: Receive DHCP REQUEST from 6C:27:79:78:13:70 98
2017 -10 -17 T17:55:42daemonnoticesyslog: Send DHCP ACK to 6C:27:79:78:13:70 with IP 10.0.0.3 106
2017 -10 -17 T17:55:42daemonnoticesyslog: DHCP server assigns 10.0.0.3 83
2017 -10 -17 T17:55:59daemonnoticesyslog: Receive DHCP REQUEST from 6C:27:79:78:13:70 98
2017 -10 -17 T17:55:59daemonnoticesyslog: Send DHCP ACK to 6C:27:79:78:13:70 with IP 10.0.0.3 106
2017 -10 -17 T17:55:59daemonnoticesyslog: DHCP server assigns 10.0.0.3 83
2017 -10 -17 T17:58:01daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T18:07:52daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T18:17:51daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T18:27:50daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T18:37:50daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T18:47:51daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T18:57:54daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T19:07:51daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T19:17:53daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T19:27:51daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T19:37:52daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T19:47:51daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T19:57:52daemonalertkernel: Intrusion -> IN=ppp1.1 OUT= 82
2017 -10 -17 T20:02:37daemoncritkernel: eth0 Link UP 100 mbps full duplex 86
2017 -10 -17 T20:02:41daemonnoticesyslog: Receive DHCP DISCOVER from 00:21:CC:CD:15:F5 99
2017 -10 -17 T20:02:43daemonnoticesyslog: Send DHCP OFFER to 00:21:CC:CD:15:F5 with IP 10.0.0.4 108
2017 -10 -17 T20:02:45daemonnoticesyslog: Receive DHCP DISCOVER from 00:21:CC:CD:15:F5 99
2017 -10 -17 T20:02:45daemonnoticesyslog: Send DHCP OFFER to 00:21:CC:CD:15:F5 with IP 10.0.0.4 108
2017 -10 -17 T20:02:54daemonnoticesyslog: Receive DHCP DISCOVER from 00:21:CC:CD:15:F5 99
2017 -10 -17 T20:02:54daemonnoticesyslog: Send DHCP OFFER to 00:21:CC:CD:15:F5 with IP 10.0.0.4 108
2017 -10 -17 T20:02:54daemonnoticesyslog: Receive DHCP REQUEST from 00:21:CC:CD:15:F5 98
2017 -10 -17 T20:02:54daemonnoticesyslog: Send DHCP ACK to 00:21:CC:CD:15:F5 with IP 10.0.0.4 106
2017 -10 -17 T20:02:55daemonnoticesyslog: DHCP server assigns 10.0.0.4 83
2017 -10 -17 T20:05:23daemonwarnradvd[6422]: sendmsg: Invalid argument 83
2017 -10 -17 T20:05:23daemonwarnradvd[6422]: Exiting, sigterm or sigint received. 94
2017 -10 -17 T20:05:23daemonwarnradvd[28082]: sendmsg: Invalid argument 84
2017 -10 -17 T20:05:25daemonwarnradvd[28082]: sendmsg: Invalid argument 84
2017 -10 -17 T20:05:25daemonwarnradvd[28082]: Exiting, sigterm or sigint received. 95
2017 -10 -17 T20:05:25daemonwarnradvd[28181]: sendmsg: Invalid argument 84
2017 -10 -17 T20:05:27daemonwarnradvd[28181]: sendmsg: Invalid argument 84
2017 -10 -17 T20:05:27daemonwarnradvd[28181]: Exiting, sigterm or sigint received. 95
2017 -10 -17 T20:05:27daemonwarnradvd[28305]: sendmsg: Invalid argument 84
Thank you very much
#CPE_October
  • Rory
    Rory Posts: 120 image  Ally Member
    @FrantaBrabec2017
    What's the complete firmware version?
    Do you encounter any problem with VMG1312B30B when the log display?
  • Ansa
    Ansa Posts: 44 image  Freshman Member
    Hi FrantaBrabec,
    Are you using IPv6 in your network?
    It looks like radvd which is using for ipv6 has some error, however, the logs don't shown too much about it.
    If your IPv4 networking is working properly.
    Maybe you could disable IPv6.
    Otherwise, it would be good that you can also share the firmware version you used.
