Is DEL-1202 affected by recent security flaw?
Xaqron
Hello. What about older products such as DEL-1202 ?
Is this model affected? If yes, would you publish new firmware for it?
#CPE_October
#CPE_October
Hey guy, my home have same model DEL1202-T10B, after asked my ISP for this model, they will fixed the security issue as soon as possible, but they don't have correct date to solved the problem, may you also can check with your ISP also, maybe they have answer for it and you can share with me.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
