cannot access web interface
Maddog265
The IP address will not work for the VMG 1312-B10D model using the default IP add: 192.168.1.1 any suggestions??
#CPE_November
#CPE_November
@Maddog265
You can check it any router's subnet mask as 192.168.1.0 in your network,
If yes, then try to change the subnet mask of router.
If not, you can try to reset your VMG device.
ftp://ftp.zyxel.com/VMG1312-B10A/user_guide/VMG1312-B10A_1.00.pdf
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
