How should you install an externder in a network
Bjrn
Bjrn Posts: 1 image  Freshman Member
Problem to connect WRE6505 to Netgear CG3700EMR router
  • MiMi
    MiMi Posts: 7 image  Freshman Member
    @Bjrn
    You might use university repeater to extender your network .You could go to GUI select Netgear Wi-Fi SSID and type its password. Then wait for device connection up, then you can use it.
