LTE4506-M606 Web GUI for connected devices information
FreemanJJ
FreemanJJ Posts: 45 image  Freshman Member
Fourth Anniversary
edited November 2017 in Smart Home Product
I connected LET4506-M606 through cellphone's Wi-Fi and notebook's Ethernet port, but the manage page only shows a Wi-Fi device without my notebook device in list
#LTE_November
  • YeK
    YeK Posts: 150 image  Master Member
    Hi FreemanJJ,
    I cannot find the same situation as yours. The icons are different between wireless and wired connection. You might turn off/ turn on your network card of netbook to check again.
  • FreemanJJ
    Fourth Anniversary
    I used the NB for wired connection to login web gui and there are no any device connection in list then connected to cellphone the list Wi-Fi device only. Is the problem for my operation?
  • FreemanJJ
    Fourth Anniversary
    I check this function again this time I log in web gui through Wi-Fi accress, the connection list still not find any wired device connection.
    is this a single case on my LTE4506-M606?
  • Ansa
    Ansa Posts: 44 image  Freshman Member
    May I know if your NB is using static IP or not?
    Please telnet to your LTE4605 and use "arp -a" to check if the MAC address of your NB is in the table or not.
  • FreemanJJ
    Fourth Anniversary
    Hi, Ansa
    No for static IP. you can check below pictures.
  • Zyxel_Kelly
    Zyxel_Kelly Posts: 40 image  Freshman Member
    @FreemanJJ
    Thank you for choosing Zyxel product.
    In order to provide you with a better assistance,
    we will contact you through private message to get information,
    please check your message box.
