Problem with the time scheduling with zyxel 8823 50b
fafo87
hi, i have a problem with the time scheduling of my zyxel 8823 50b. I want to setup an active time between 07 in the morning and 01 in the night, but it says that is not allowed because 01 is littler than 07 -.- ....it goes only to 23:59 and more is not allowed.. solution?
#CPE_November
#CPE_November
I think Rory answered the right solution.
It need to create two rules0 -
i have already do that before to write here..i must check if it works...because i think that betweene 23:59:00 and 23:59:59 the wifi is down0
It seems you are using Access control to archive what you need right?
Maybe you could try to use parental control to define two rules for the active time.0 -
yes but i want to set off the wifi, only for not to have the wifi on....the LAN internet can be on0
You are right, there would be one minute that wifi would down.
hi I have seen that the wifi led does not turn off... how I can do this with a schedule? thanks0
do you mean turn off the wifi LED via the schedule function?0
- 441 Beta Program
- 292 Service & License
