LTE4506-M606 Web GUI bugs in cellphone
FreemanJJ
Posts: 45 Freshman Member
Hi, I used my cellphone to log-in LTE4506-M606, I found there are some function missing:
- No Router, Application & System setting pages
- Wi-Fi 5G encryption type was missing
- Can not back to home page, there is no any button to back home and when I back to previous page the GUI swap to log-in page and shows a message box for "someone has logged in". The only way I can do is just press log-out button then re-log-in again to selection other function
#LTE_November
#LTE_November
You can click desktop version at the bottom of the screen and you can login LTE again. it would show the setting pages
I could see the page at my side.
-Can not back to home page.
Please click the close link at the upper of the screen and it would back to the page.0 -
Hi,Ansa
=> I think you are not get a right answer, infect there are no these functions means not completed Web HUI. that is no sense you said swap to desktop version.
=>again, have you check what is I mention? you can see SSID1 or in desktop Webpage for SSID2. the auto encryption is missing.
=> yes, thanks your information shared, but don't you think how the design can be easy to use for normal users?0 -
@FreemanJJThank you for choosing Zyxel product.In order to provide you with a better assistance,we will contact you through private message to get information,please check your message box.0
I used two Chrome & Samsung default browsers to login web GUI I think the web page are unstable for some functions.
In Chrome when page into SSID2 that I found Encryption type for "Auto..." was missing, but when re-select encryption mode switch WPA and WPA/WPA2, then the encryption type "Auto...." will pop out on screen. After that the encryption type "Auto..." is always on screen when I change any other pages then back to SSID2. The 2nd time I try by Samsung default browser this type also missing in some time when I selected SSID2 pages.
Hi FreemanJJ,I think it’s the same as SSID1, no matter you use NB or other cellphones. Wi-Fi Alliance prohibits TKIP devices under WPA2 mode, but allows it under WPA/WPA2. It’s why you cannot find auto options under WPA2 mode.0
You haven't explain why this WPA/WPA2 is unstable to show on SSID2 page
- 393 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 51 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 906 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
