USG-20W Web-interface connection failed.
Aero
Aero Posts: 4 image  Freshman Member
edited April 2021 in Security
Hello!
I have personal device - Zyxel Zywall USG-20W, since i use Windows 10 i can't connect to it via web-interface (to local IP 192.168.1.1), different browsers write me different errors, for example: "Chrome": ERR_CONNECTION_CLOSED, "Edge" and "IE": Old TLS protocol used. As far as i understant web-inteface use SSL 2.0 connection which Windows 10 don't support anymore? How i can connect to web-interface of my device in my situation? Or i need OS with SSL 2.0 support (Windows 8.1)? Thank you!
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    I can access to usg without any issue. (Using windows 10)
    I think you can try to follow the troubleshoot from chrome helper. https://support.google.com/chrome/answer/142063?co=GENIE.Platform=Desktop&hl=en
  • Aero
    edited December 2017
    No, no any chance to get into device via web without SSL 2.0 browser support, i build a VM to get old Internet Explorer (11.0.9600.17416) with SSL 2.0 support and login into. So, question number two! My device is ZyWALL USG 20W (Not 20W-VPN) firmware last (3.30(BDR.9) from 2016-11-22 10:05:22 and boot module 1.14), is my device have Wi-Fi KRACK issue? There is no any firmware updates to me and no any info about issue.
  • zyman2008
    zyman2008 Posts: 241 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    I rember Zyxel has some unofficial release firmware for the old USG model.
    Which support the new TLS protocol.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @Aero,
    For your case,
    the Firmware: 330BDR9ITS-WK48-r74988 can support TLS 1.2 protocol, therefore, I will private message the firmware to you.
    Moreover, the Zywall USG Series will not be affected by the issue of Wi-Fi KRACK(Immune).
    Charlie
  • Aero
    Yep! Firmware loaded and work, but web login situation are the same, it don't work, browsers write me what i "Can't safely connect to this page". Maybe i need change some device setting? I look in "Configuration -> System -> WWW" But no any major setting about this, all by default and all looks pretty right! I can login from Windows 8.1 but can't from Windows 10. :-(
  • zyman2008
    Maybe you can check the certificate of USG20 is SHA2 signature or not.
    If it not, then generate a SHA2 certificate and change certificate to this one.
  • Aero
    edited January 2018
    I generate new Certificate with device web-interface, then set it by default, no any changes, login from Windows 10 don't work. I think this device out of date. Finish at this point, thank you! :-)
