MWR102 -- where did its web gui go?
JackElliott
I've set up my new MWR102 as an access point. It was adopted by the house's network and is now working fine. But I'd like to check a few settings, and can't find it on the network. NMAP and Angry IP Scanner cannot find its IP address. How can I access it? Perhaps the webgui goes down once the device has been set up?
#Others_January
#Others_January
@JackElliott
Did you try to open a browser and type in 192.168.100.1?
You can also check MWR102's IP from DHCP client list of your router.0 -
Thank you, Rory. I'm using the MWR102 with a router that is not mine, it's provided by an ISP and they've changed the default login creds so I can't get into it. 192.168.100.1 doesn't work, the subnet I'm on, and which the router and the MWR102 are using, is 192.168.1.nnn.
Hi Rory,
Um . . . how do I say this. Ah -- "duh." No I didn't. Thanks for the tip, I am not nearly as bright as I wish I was.
@JackElliottIn order to provide you with a better assistance,we will contact you through private message,please check your message box.
- 588 USG FLEX H Series
- 477 News and Release
