NAS326 DLNA problem
Sounder
Sounder Posts: 2 image  Freshman Member
edited January 2018 in Personal Cloud Storage
Dear Everybody,
I have problem with my NAS326 (FW: V5.21(AAZF.1)C0).  The DLNA server lost the settings, and I have chose a bad file sharing folder, that I can't change now. I tried the soft+hard factory reset, but nothing changed.
The questions:
1. How can I change the DLNA sharing folder?
2. How can I reset all settings?
3. How can I downgarde the FW?
Please, it is important for me, and I can't use the DLNA now. :(
Thanks!
S
#NAS_January
  • Rory
    Rory Posts: 120 image  Ally Member
    @Sounder
    You can reset configuration via reset button.
  • Rory
    Unfortunately, as I know the FW can't be downgrade.
    The DLNA works via Media Server,
    so you can go to Control Panel > Media Server > Share Publish select the folders or file types.
  • Sounder
    Dear Rory,
    Thanks for your answer! I tried this (the back reset button).
    I pulled out HDD before I reseted it, but after the HDD instalation didn't change the DLNA settings.
    If I could change the below "Shared folder" I thing everything will be good, but I can't change this folder. Do you have other idea?
  • Mijzelf
    Mijzelf Posts: 3,071 image  Guru Member
    My 520 has a directory /i-data/sysvol/.media/twonkymedia. I assume a 326 has the same directory. You can try to rename it and reboot.
