NAS326 DLNA problem
Sounder
Dear Everybody,
I have problem with my NAS326 (FW: V5.21(AAZF.1)C0). The DLNA server lost the settings, and I have chose a bad file sharing folder, that I can't change now. I tried the soft+hard factory reset, but nothing changed.
The questions:
1. How can I change the DLNA sharing folder?
2. How can I reset all settings?
3. How can I downgarde the FW?
Please, it is important for me, and I can't use the DLNA now.
Thanks!
S
#NAS_January
The questions:
Thanks!
S
#NAS_January
Unfortunately, as I know the FW can't be downgrade.
The DLNA works via Media Server,
so you can go to Control Panel > Media Server > Share Publish select the folders or file types.
Dear Rory,
Thanks for your answer! I tried this (the back reset button).
I pulled out HDD before I reseted it, but after the HDD instalation didn't change the DLNA settings.
If I could change the below "Shared folder" I thing everything will be good, but I can't change this folder. Do you have other idea?
My 520 has a directory /i-data/sysvol/.media/twonkymedia. I assume a 326 has the same directory. You can try to rename it and reboot.0
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
