GS1900 & GS1920 Web interface refreshes with wrong IP.
We have 15 or so GS1900/1920 switches deployed that are all on internal private addresses. We have port forwards setup on the firewalls that are restricted access to specific IP addresses on the outside that can connect to them. What we are seeing is that after being connected to these switches for a couple minutes, they do a page refresh but refresh to the private IP. Is there something that is set wrong or is this a bug in the code that does the page updates?
An example of this would be that I connect to public IP 123.123.123.123 on port 11000 with a web browser and login. After a couple minutes, the page will try and refresh the browser to IP 192.168.1.2.
We are running version 2.30(AAHM.0) on the 1900 units and I believe the 1920 are running the latest version as well.
Any help or ideas people can provide would be greatly appreciated.
Hi @Troyb,
Welcome to Zyxel community!
The symptom you encounter is the behavior on GS1900 series with the firmware version V2.30.
We have already enhanced this behavior in the FCS firmware version V2.40.
You may download it from the link below:
https://www.zyxel.com/support/download_landing/product/gs1900_series_12.shtml?c=gb&l=en&pid=20130521174809&tab=Firmware&pname=GS1900%20Series
BTW, GS1920 doesn't have this symptom, please feel free to use.
Hope it helps.
Jason0
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 481 News and Release
