Windows 10 Can't See USB Share (XMG3512-B10A)
HopuefulJ
I'm sure its something simple so my apologies in advance. Basically I insert my USB stick into my Zyxel
XMG3512-B10A but my Windows 10 PC apparently cannot map to it.
Any help would be great!
#CPE_February
@HopuefulJ
You can try to enable SMB1.0 in Win10 as below:
https://homeforum.zyxel.com/discussion/comment/1716#Comment_1716
Just tried it like Rory mentioned to enable the SMB1.0.
Then it need to put the path into the folder column like:
\\192.168.1.1\usb1_sda1 (My LAN port IP address is 192.168.1.1)
Afterward, my windows 10 can map it and shown as below
Thank you guys, I think Rory's suggestion "You can try to enable SMB1.0 in Win10" got me closer.
1. After following that step and restarting my PC I now see this.
2. So Ansa's suggestion resulted in this progress!
3. So then I clicked 'Diagnose' and got this
I l
4. So I double checked my share just to make sure.
Am I missing something? I even tried mapping again using this path==> \\192.168.200.1\mnt\usb1_sda1\ZYXEL but still the 'diagnose' result is that windows can't find 'mnt'.
Rory,
I cant find your last message but I wanted to thank you for suggesting the share path as shown below following your SMB1.0 suggestion. Your SMB1.0 suggestion is what made this share path work.
\\192.168.200.1\ZYXEL <<<< THIS WORKED!
And thanks to everyone for your help .
Sincerely...
- 588 USG FLEX H Series
- 477 News and Release
