How do I repair my bricked Zyxel NWA1100-NH?
-M
#Biz_WLAN_March
@mbradleych
If you have the console cable to connect NWA1100-NH.
Please refer to below operating procedure to do firmware recovery.
Topology:
PC or Laptop (Static IP: 192.168.1.222 / Subnet mask: 255.255.255.0) --------------LAN <Ethernet RJ-45> ------------------NWA1100-NH
SETUP/STEP BY STEP PROCEDURE:
Steps:
1. Download the TFTP tool and run it on the laptop.
2. Connect a laptop wired to NWA1100-NH. Configure a static IP address on the laptop's NIC card. The IP address is 192.168.1.222 and Subnet mask is 255.255.255.0.
3. Disable Windows Firewall before recovering.4. Unzip the image file. For example "V212AASI0C0.bin" for NWA1100-NH.
5. Unzip the image file. For example " V212AASI0C0" for NWA1100-NH.
6. Copy two files "mi124_f1e-jffs2"," vmlinux_mi124_f1e.lzma.uImage" to the TFTP server folder.7. Connect to NWA1100-NH through a serial port. Setup the serial port for the baud rate 115200, data 8 bit, parity none and stop 1 bit.
8. Power-on the NWA1100-NH.
9. Press any key before the prompt counts down to zero.************ Post Result *******************
POST memory PASSED
POST uart PASSED
POST ethernet PASSED
Hit any key to stop autoboot: 4
10. Setup the IP address.
>setenv ipaddr (AP IP address)>setenv ipaddr (The laptop's static IP address)
11. Upgrade the kernel.
>run lk12. Upgrade the filesystem.
>run lf13. Reboot the device.
>resetIf you don’t have any console cable on your hand and you tried to do above but the symptom is the same.
Please contact the local reseller.
Hi together! I have also the problem, that my NWA1100n is bricked after failed update. So I've searched for a console cable. Can you tell me which one I must use? Seriell to RJ45 or USB to RJ45 or which one?0
Hi @Ludibubi
Your AP is NWA1100-N without NWA1100-NH, right?
If so, NWA1100-N is a legacy AP which is not supported the console port.
Below is how to update the firmware via FTP method on NWA1100-N, please try to do it.1. PC connects to NWA1100-N and configure PC's IP in same subnet.
2. Copy firmware to C:\ and change file name of firmware to ras with no extension.
For example,
100AAQ3C0.bin is changed to ras3. Open command window on PC to load firmware and its path moves to C:\
3-1 ftp 192.168.1.2-------------->NWA1100-N IP
3-2 admin-------------------------> device username
3-3 1234-------------------------->device password
3-4 bin--------------------------->transmit data in binary mode
3-5 put ras -------------> firmware filenamePlease await FW write time done.(LED SYS and WLAN both are green)
Thanks!
Hi! Thanks for reply. I tried this without success. I think the problem is that the AP is bricked and so the interface is not reachable because it doesn't recognize the IP-adress and cannot answer. Any other idea?
Regards Ludgdr0 -
Hi @Ludibubi
Please run the RMA process with local agent.
But actually this legacy AP is EoL for a while.
I think the warranty period should be expired too.
Thanks!
What do you mean with "run process with local agent"?0
My boss gave it to me because we don't need it anymore in our company. I don't know wäre it was purchased.
Regards Ludger0
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 458 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
