Modem AMG1302-T15C firmware
Wemerson
Hello, I'm trying to find the modem firmware, but I can not find anything on the Zyxel website
Current Firmware Version V2.00(ABBZ.0)b10_v3
#CPE_March
#CPE_March
Hi Wemerson,
Please send this request to your service provider because this version will not upload on our website.
Hi Wemerson,
I need the FTP / SSH username and password of this router as superuser.
In Portuguese for the people who are with this modem from Oi
A Oi modificou o rom desse modelo, tanto que a ZYXEL não pode colocar a ROM original no site, se tivesse seria ótimo. O grande problema é que eles criaram um super usuário (sem ser o default Admin) com acesso a menus avançados da configuração, como FON / Public WiFi, com isso eles estão compartilhando minha internet sem minha permissão (já fiz o procedimento de negar pelo formulário, mas nada adiantou).
Algumas versões antigas do firmeware ainda exibia os menus, contudo só permitia o acesso quando fizesse o login com o 'super' usuário.
Quem quiser testar algumas senhas só acessar a url direta:<a href="http://192.168.1.1/advanced/adv_PublicWifi.htm" title="Link: http://192.168.1.1/advanced/adv_PublicWifi.htm">http://192.168.1.1/advanced/adv_PublicWifi.htm</a><a href="http://192.168.1.1/advanced/adv_fon.htm">http://192.168.1.1/advanced/adv_fon.htm</a>
Hi fabricio
It seems Oi is a member of FON which would share a small part of the router's WIFI bandwidth to other FON members if the router comes from Oi's package.
Only FON member has the permission to use your shared FON WIFI, and on the other side you can also use other FON members' WIFI since you are also a member of FON.
That's is the reason that FON / Public WiFi was enabled on your router.
I believe Oi, such a big ISP, has its own remote management system, and able to disable/enable functions remotely.
Therefore, even you disable FON by yourself, it might still be enabled by remote management system.
So, If you still would like to disable it, it is better you check with Oi.1 -
Olá.
Conseguiu arrumar o firmware desse modem?
Não consigo achar em nenhum lugar mesmo.
Hi Jandersonvs
You need to check with Oi for the firmware.
This model seems a customized FW for Oi, so the firmware was controlled by Oi.0
- 588 USG FLEX H Series
- 476 News and Release
