firmware download lte3311-Q222
greater007
greater007 Posts: 4 image  Freshman Member
edited March 2018 in Smart Home Product
Icant find firmare nowhere. I am so confused. mayby i am missing it somehow. I need help. please?
#LTE_March
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188 image  Zyxel Employee
    Sixth Anniversary
    edited March 2018
    May I know where did you buy the LTE3311-Q222?
    What is the current firmware version?
  • greater007
    Well I bought that from Estonia, Elion company.
    firmware V1.00(ABDE.4)C0
  • Zyxel_Support_CPE
    Sixth Anniversary
    V1.00(ABDE.4)C0 is latest fw for Estonia LTE3311-Q222. Do you find any issues on your device?
  • greater007
    My router software dosent support bandwidth. There is no option for that, I am pretty sure i am not missing it.
    I am having problem that my router is limiting speed. Allready fixed in computer bandwidth but somereason my router did restart and is not recognizising my settings. I have readed forums easy fix is to get router bandwidth settings change speed manually.
  • greater007
    edited March 2018
    Mayby someone has any other solution if i cant get access to router bandwidth.
    Problem is my internet speed is 1,7mb/s i didtest on speedtest. When i download on steam it shows 1,7mb/s. But it goes to 600kb/s and dosent go higher. Its limit 600kb/s some reason. I have fixed once when i went computer system settings what was internet speed income i puted 100% and it worked long time until my router did restart. Now setting dont work some reason. Like i got 1,7mb/s when i fixed. Now its back 600kb/s and its not going higher even speedtest show peak is 1,7mb/s. Its auto speed limit what makes it bugged or someting. thats why i need to change manually.
  • YeK
    YeK Posts: 150 image  Master Member
    Hi greater007,
    How did you get the value “it goes to 600kb/s and doesn’t go higher”? Did you use any Windows tool to measure the downlink speed?
    What is the settings on your computer in order to allow the speed not limited to 600 kb/s? Is there any screenshot you can provide in order to show the settings?
