Zyxel Multy X - Country Code
Joakim
I bought my 2 pack Multy X in Norway and when checking the 802.11d Country Code it gives me CH.
I live in NO country code and the frequencies are different here.
Can you please explain why the router does does not setup with the NO Country Code?
I am missing 104, 108, 112, 116, 120, 124, 128, 132, 140 channels due to this.
Joakim
#MultyX_March
Joakim
#MultyX_March
All Multy X devices used in EU, the country code is CH.When you have installed more than two Multy X devices, your wireless client only can see channel 36, 40, 44, 48. Channel 104, 108, 112, 116, 120, 124, 128, 132, 140 is using for wireless dedicated backhaul.If you have installed only one Multy X device, your wireless client can see 36, 40, 44, 48, 104, 108, 112, 116, 120, 124, 128, 132, 140. Because only one Multy X device, it does not required wireless dedicated backhaul.1
May I know how do you check it? Which command did you enter?- When checking the 802.11d Country Code it gives me CH.- I am missing 104, 108, 112, 116, 120, 124, 128, 132, 140 channels due to this.0
Macbook. Hold down the option button and choose the network symbol on the top. It will provide info about Country Code, RSSI, BSSID among other things.0
Ok. Good answer.
Thanks.
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 322 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
