why I I'm not able to login routers web interface to change settings?
jan
i have router NBG6616 an this site says that I have to use address 192.168.1.1 to login my web interface but safari says it can't download this page ?
what should I do ?
#Router_March
what should I do ?
#Router_March
@jan
Have you checked the IP address your PC gets when connecting to NBG6616?
For example, if your PC gets 192.168.10.100, then I think you can try to access the WebGUI of NBG6616 with IP 192.168.10.1.
You can also reset the NBG6616 and then you will be able to access its WebGUI via 192.168.1.1 because it is the default LAN IP of NBG6616.
i have a osx.
no ihavent checked that, i thought that i just have to use only this address 192.168.1.1.
If i understand right, i have to change the last part of this 192.168.1.1, to same that my ip is using?
i have reseted router allready couple times, it didn´t help.
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
