Daisy Chain on Multy
Gulstripe
Hi everyone.
After the newest update, daisy chain is finally an option to which to choose. But after running the speed diagnostics I'm confused... (2018/04/04 23:46:41)
I'm sharing a screenshot from my latest speedtest while on daisy chain and I find it strange that my number one node "Vaskerom" acts like it still on star topology setup. Notice the speed check from node to node (not internet - node) It appears like the main node "Vaskerom" is checking the speed to nodes 2 "Hall Nyhehuset" and node 3 "Stue/kjøkken" separately, like its still in Star topology.
I hoped and expected it to be "Vaskerom" to "Hall Nyehuset" to Stue/kjøkken" (node 1 to node 2 and node 2 to node 3)
Appreciate all feedback on the matter.
#MultyX_April
#MultyX_April
Notice the speed check from node to node (not internet - node) It appears like the main node "Vaskerom" is checking the speed to nodes 2 "Hall Nyhehuset" and node 3 "Stue/kjøkken" separately, like its still in Star topology.> This is current design (from 1st node to other nodes). Multy X is supported dynamic daisy chain. It means if 3rd node getting a stronger signal from 1st node (better than 2nd node), it will connect to 1st node automatically.I hoped and expected it to be "Vaskerom" to "Hall Nyehuset" to Stue/kjøkken" (node 1 to node 2 and node 2 to node 3).> Thanks for your feature request in Multy X, we will evaluate it. And I have moved this post to Ideas Discussions.1
- 245 Nebula Ideas
- 6.9K Security
- 813 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
