Asus computer with windows 10 doesnt find the router
rastaramses2
rastaramses2 Posts: 1 image  Freshman Member
edited April 2018 in Home Router
I have a Asus F552C and recently it stopped recognising my home wifi network that uses a ZyXEL NBG-418N (not v2). It can find other wifi networks, and my other devices find the home networks, so it must be a problem between the router and computer.
Any fixes? I've tried all the tricks i know on the computer software (instaling/reinstalling/updating network drivers and so on)
#Router_April
  • Zyxel_Kelly
    Zyxel_Kelly Posts: 40 image  Freshman Member
    edited April 2018
    @rastaramses2
    Glad to see you on forum. :)
    Maybe Asus devices only recognize specific channels,
    you may try to disable Auto Channel Selection and change wireless channel of NBG418N as Channel-01.
    If problem still only exist on Asus devices,
    we suggest you can also check with Asus support team.
