Port forward
Hi
I´m new here. I have one Zywall20 USG VPN after one Thomson TG585 configure with bridge. I need no forward a port 9000 to an internal IP. I do everything explain in tutorial, creating a NAT rule and a policy rule, but not working. On the dashboard of the zywall on the WAN port it show me an IP like 192.168.1.79 ( TG585 is 192.168.1.254 ) . My Zywall as the IP 192.168.8.1. I can not access too my Zywall remotely. Any help ?
Hello JMF,
I want to confirm with you that do you mean you cannot remote access to the USG's internal Ip with port 9000? If so, please confirm the below steps.
Go to configuration> NAT
Go to Object> Service to create the profile of port 9000
Allow Wan->Lan1 with port 9000
Or if you cannot remote access to USG, please follow below steps.
Since the access session is blocked by firewall, so let client can access zywall by creating rule on firewall. Please follow an example as below.
Go to WWW >change the server port to 11111 and press apply
Go to the service create the new service
Go to policy control> create the rule wan->zywall and select "wantozywall" service which I created on service field.
At last, press your wan ip with port number"11111"
Note: If there is NAT router before the USG in this topology, you need to configure NAT rule to make traffic flow into internal device.
Moreover, please share the topology of this case with IP address.
Charlie0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
