I can not connect my iphone and ipad
lionlin7
I can not connect my iphone and ipad to the new lte4506-m606 by wifi. But Android phones are ok,why? What should I do ?
#LTE_April
#LTE_April
Hi linolin7,
I have IPhone6 plus/IPad air2 and both devices connect to LTE4506 are no problem.Do you find 2.4G or 5G SSID on your iphone/ipad? Does it happen after you use for a period time? Or happens after device boot up? You might disable/enable wifi on both LTE4506 and your iphone/ipad to check if it can be resolved or not.
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
