SBG3300-N bricked, how to recover back.
mlml139
my SBG3300-N bricked, 4 lan port can used as switch, Plugging an Ethernat cable from router to PC, connection light comes ON but no IP address is assigned to PC, tried assigning address to PC in the range of 192.168.1.x manually and couldn't ping the router on either .
Was wondering if there is another procedure to restore the firmware? maybe via USB or using some application that can access the router over some different protocols?
#Biz_Security_April
#Biz_Security_April
Hi mlml139,
The procedure as below,Step 1
Set PC IP:192.168.1.100/24
Setp 2
Set console rate: 115200
Step 3
Power up SBG. Press any key to CFE mode
Setp 4
Go to Update Software web page via http://192.168.1.1.
Step 5
Click "選擇檔案" to select firmware (XXXXX.bin)
Step 6
Click "Upgrade Software" to upgrade SBG
Thanks will try when i back to south africa.0
how is this 4 jumpers work. i tryed tx2 rx3, gnd 5, no data come.
this is the light like after swich on. if u pulg lan cable, the port light will on, is this broken or still can recover back?0 -
after i connect ttl there is nothing come out,
did tried set IP but can not ping 192.168.1.1.
was update fireware online, then dead.0 -
looks like no rom in eprom, is any way to recover back?0
- 588 USG FLEX H Series
- 476 News and Release
