PLA 5206 Internet Speed Problem
Bsu
I have got PLA 5206 v2 powerline. When I connect PLA device with Pc case same electric source, internet speed so slowly..
I test it (PC turned off) with laptop; my internet speed is 45 - 48 mbps
PC and PLA connected same electric source; internet speed is 5 - 20 mbps (http://www.speedtest.net/result/7219384599)
PC and PLA connected different electric source; internet speed is above 40 mbps
My sistem properties;
I connected PLA devices same electric source internet speed above 47 mbps (PLA devices distance max 10 cm)
What is my problem? Thanks.. (Sorry for my poor English)
#PLA_April
- Tilgin 2331 fiber router ( Internet speed up to 50 mbps)
- Aerocool 500W VX active PFC psu
- MSI A68HM GAMING Amd A68H 2400MHz(O.C.) DDR3 Soket FM2+ mATX
- AMD A10 7870K Near Silent 4.1GHz 4MB Cache Soket FM2+
- CAT6 or CAT5e cables (Max 2 meter)
#PLA_April
Can you help me?0
Same PC and PLA change eletric socket, then the speed can upto 40Mbps, I think this might be compatibility case, because the performance will be affected by noise in powerline and some of electric socket's quality.
Thanks. I am using same electric source, when PC case turned Off or turned on.. Something affected pla devices when PC case turned on.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
