Mounting USG210
Jarno_Smits
good morning,
bought a USG210, official this type isn't for wall mounting.
but are there some people here, that mount a USG210 to a wall already?
i want to mount it vertical to the wall,(with custom made clips ) around the USG210 there is enough airflow.
I have a USG60 and noticed this type doesn't get hot, when wall mounted, If this is also with the USG210 then i think wall mounting isn't a problem.
kind regards,
Jarno Smits
kind regards,
Jarno Smits
Hello Jarno Smits,
For the USG210, we suggest it should place on the table or rack(the original design), however, I think USG210 can be mounted on the wall if you keep enough airflow for ventilation hole of device,
Charlie0 -
Hi Charlie,
Thank you for the answer, i,m gonna try the wall mounting and monitoring the temperture, there is enough airflow at the ventilation hole.0 -
Hi Charlie,
Some feedback.
Zywall is working for a month now, wall mounted, it works without a problem, temperature is ok.0
- 588 USG FLEX H Series
- 476 News and Release
