can I configure QOS in GS1900 for multicast streams?
Hi @kevin,
You can use QoS setting on GS1900 with following steps.
1. Access the Switch via WebGUI.
2. Go to Configuration -> QoS -> General and choose the specific port (The port connected with stream server) to configure CoS Value to the priority you want. (Don't recommend to configure the highest priority 7 because priority 7 packet is usually reserved for the system packet.)
3. Go to Configuration -> QoS -> Trust Mode -> Port to configure port mode "Trust" on the port connected to stream server.
Then your stream should be set priority.
Ryan0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
