zyxel VMG3925-B10B router & samsung UE40ES7000 (TV) WI-FI ISSUE? ~ "SOLVED!"
the_doc735
My samsung UE40ES7000 (TV) will NOT connect wirelessly to my new zyxel VMG3925-B10B router?
TV is not faulty as it still connects wirelessly with my old Netgear router DGND3700v2.
So, must be a configuration issue somewhere?
Any ideas?
Thanx!
#CPE_June
Any ideas?
Thanx!
#CPE_June
SSID is correct.
WPA2 SPK (AES) is correct.
MAC address security: DISABLED.
Router channel: AUTO (currently '6').0 -
To help anyone else with same problem. I plugged a 'cat5' cable/ 'wired' in and looked at the auto configured IP settings:
IP: 192.168.1.211
MASK: 255.255.255.0
GATEWAY: 192.168.1.1
DNS: 212.50.160.100
I then manually entered these settings into the 'wireless' configuration window/fields.
It worked!0 -
Hi the_doc735,
There is just the Samsung UE40ES7000 cannot connect to VMG3925-B10B? Is other wireless devices can add VMG without problem? Does it happens if you reset both VMG3925 and Samsung UE40ES7000?
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
