Static routes are not saved
Voha
My router is Keenetic Start
My firmware is NDMS v2.05(AAKV.0)C7
I create static routes and its work fine. But after a reboot its do not available in the web interface and don't work. Although they are stored in startup-config and running-config :
#Others_June
ip route 10.0.0.0 255.0.0.0 192.168.9.1 ISP auto 1 ip route 78.111.186.0 255.255.255.0 192.168.9.1 ISP auto 1 ip route 192.168.9.0 255.255.255.0 192.168.9.1 ISP auto 1If I do not specify an interface ( ISP ) , the routes will enable in the web interface and will work after the reboot. How can I make the routes work after rebooting with the selected interface?
#Others_June
Hi Voha,In order to provide you with a better assistance,I will contact you through private message,please check your message box.
- 588 USG FLEX H Series
- 476 News and Release
