NBG4615
PROCOSQ
PROCOSQ Posts: 1  Freshman Member
edited June 2018 in Home Router
After firmware update using the bin file named "100BWQ4C0.bin" in "NBG4615_1.00(BWQ.4)C0.zip", I have access to internet but I can't acces to the web interface configuration.
#Router_June
  • Penny
    Penny Posts: 65  Ally Member
    Hi PROCOSQ,
    Can you share more information about your problem?
    .What is your topology?
    .What is "Sys OP Mode" of your NBG4615? (Router/AP/UR...)
    . Do you try to reset NBG4615? Is the problem still exist?
    .Which IP address that you input to access NBG4615 web interface?
    .Is there any message/screenshot when you access to the web interface configuration?
    .Do you know the IP address and default gateway on your PC/devices?
