Camer won't connect
I am having this exact problem as well! Is the firmware available on your download site? I'm currently running V1.00(ABFE.2)C0
@timgiwo,
I have sent you the firmware link of GS1200-5HP via private message. Please kindly check your message box.
Hey, I have same / similar issue. I have a GS1200-8 and the link is not coming up or sometimes it comes up as 10Mbit/s which is not correct, it is 100Mbit/s. With my older Netgear it works stable on 100Mbit/s. I'm on Fireware V1.00(ABFE.4)C0. Could you provide the special Firmware you mentioned above? Or what can I do to get the link up stable at 100Mbit/s ?
Thanks and kind regards,
Bjoern0 -
Hello, i'm having the same issue with amcrest POE Cameras and the gs1200-5hp.
Looks like i was trying to install the V2 firmware, i found the correct firmware for the V1 and updated it. . . But i still cant connect to any POE cameras connected to the switch. It seems like there might be some other firmware update people are getting through PM.If i could get it, that would be great... if not . i'm going to have to go buy a new switch !Thanks !0
@Tiberius747,
Here is the firmware to fix the problem you reported.
For GS1200-5HP:
https://www.dropbox.com/s/y624hbppqg4salc/GS1200-5HP_EEE_OFF.zip?dl=0
For GS1200-8HP:
https://www.dropbox.com/s/qzcae2n3xlpod5k/GS1200-8HP_EEE_OFF.zip?dl=0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
