VMG1312-B10D with V5.13(AAXA.7)C0 firmware
jelv
I've just upgraded the firmware to V5.13(AAXA.7)C0 and have found that the program I use to collect and store the xDSL stats has stopped working. It uses telnet to access the stats. When I've checked manually I've found that the normal commands such as xdslctl info --stats are not available.
What is the command to enter the busybox shell please?
#CPE_July
#CPE_July
Hi jelv,
I think it might not support CLI to configure/check in VMG1312-B10D.
Have you faced the xDSL disconnection issue in your device? Or you just want to check DSL stats?
Hi jelv,
*if* it's anything like the VMG8823, then you need a supervisor/root user to access the busybox shell.0 -
V5.13(AAXA.8)C0 has not re-instated the BusyBox shell but they have added xdslctl to the ZySH
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
